How to add Slack component in the Matillion ETL?
The version we have is:
Matillion ETL
Version: 1.68.13 (build 2a22b08-213264)
Image Version: 1.68.13
I would like to add slack component to my Matillion studio. I downloaded from https://exchange.matillion.com/login?startURL=/s/exchange-job/a074G00001EkCMdQAN/send-message-to-slack
But, how do I import it into Matillion? I tried import option but got "Error parsing file" message.
Regards,
Sivaji.
Hello @sginjupalli​
Welcome to the Matillion Community, it looks like you may have headed to the wrong option there, not to worry, I do it all the time!
If you follow the instructions here you can import and use the shared job you downloaded from the Matillion Exchange.
I hope that helps, let me know how you get on 😃
Hey Joe,
Thanks for helping me with that.
But, the slack component keeps failing with the below errors:
Parameter Validation Failure:
Name - This parameter is not recognized.
Script - This parameter is not recognized.
Interpreter - This parameter is not recognized.
Timeout - This parameter is not recognized.
How do I fix this?
Regards,
Sivaji.
Hey Joe,
Yes, the issue is still not resolved.
Here is the version we have:
Matillion ETL
Image Version: 1.68.13.
Hello @sginjupalli​
Are you still encountering this issue? if so can you confirm what version of Matillion ETL you are using?
Thanks Joe
Hi @sginjupalli​
We have worked out what is causing this, the component needs updating, a member of our team is doing this for us and I will add it to the exchange and inform you once it is live, this should then work as required.
I will be in contact once that has been done.
Hi @sginjupalli​,
The job has been updated. If you continue to experience any issues, please let us know!
Best regards,
Maria
Hi Maria,
What is it that I should do now to fix it on my end?
Regards,
Sivaji.
Hello @sginjupalli​
If you remove the old component and then add the new version, that should all work as intended.
Apologies for the delay in response.
Hi Maria,
I get below error when I tried to import the updated shared job.
