Is there a way to move a project to a different project group. I don't see that in the UI.
Hi @RemigiousMikevin.James and welcome to the forums! We have recently moved the forums, so I’m sorry for any confusion this has caused.
Onto your question. There isn’t an automatic way to do this, you will need to set up a new project in the correct group and then export and re-import the pipelines. I hope that helps, let us know how you get on.
