I am working on a pocket where I am using sql component in matillion and using object_construct to create a json,
My concern here is what is the max size of Jason file I can create to upload from snowflake to Azure blob using matillion.
Hello
This would be the max JSON file size Snowflake Permits, I have had a look and this document should have all the information you need on it.
