I am getting Invalid argument types for function 'IFF': error when running Job.
It is updated date job from INC table to Main table
I am using Matillion for Snowflake .
Not able find where the issue happening. can some one please suggest
Unfortunately, I can't see all the details from your screenshot. Please have a look at the SQL which is generated by the Table Update component and post the SQL code here. This should indicate what's wrong here.
Seems like first Argument is returning number in IFF statement within SQL built.
Which should ideally return Boolean value (TRUE/FALSE).
Check for all conditions that have been setup.
Thanks, I found the issue.
It is because when I am updating from stage to main table I used variable which is not found hence I removed variable
and just used “Update”
