Is anyone using Matillion for EDI / X12?
We have the same need - is anyone using Matillion for handling this type of file?
Hey @saqib​ & @RD199787
Just noticed your question and had a quick answer for you regarding this, Matillion supports anything the “COPY INTO” command supports for the target they are loading into (Snowflake, Redshift for example) I hope that helps, please do let me know how you get on!
Hi Joe,
Copy into won't work in this case. The EDI / X12 format is an XML format.
Saqib
