Is there a way to filter out all columns that start with say a particular alphabet? Is there a way to use an expression in the filter component? OR is there a way to use a Grid Variable for Field Selection? Any help please?
More details :
I'm connecting to a SQL server db via Matillion and trying to load a table into Snowflake. The table has about 70 to 80 columns. about 50 of these are that start with alphabets 'V' and 'C' . I want to be able to filter out and not load anything that starts with a C. What is the ideal way to do this? ( example of column names - V12345, C12345678) and so on
I haven't done it before, but glancing at what is available, I'd probably try this: "Table Metadata to Grid" to get column names, followed by a "Grid Iterator" to iterate over those column names. Within each iteration: for each column name, if it starts with a 'C', then do something with it; else ignore it.
Thanks for your response Kevin. I'll check this out and let you know.
I do something like below , to create the insert statement for any table dynamically :
SELECT
listagg(A.COLUMN_NAME, ', ') AS C,
COUNT(A.COLUMN_NAME) AS C_CNT,
listagg(B.COLUMN_NAME, ', ') AS V ,
COUNT(B.COLUMN_NAME) AS V_CNT
FROM DATALAKE.INFORMATION_SCHEMA.COLUMNS A, DATALAKE.INFORMATION_SCHEMA.COLUMNS B
WHERE A.COLUMN_NAME = B.COLUMN_NAME AND A.COLUMN_NAME NOT IN ('LAKE_LOAD_ID','DATA_DT') AND
A.TABLE_NAME = TRIM('${L_LAKE_TABLE_NAME}') AND B.TABLE_NAME = TRIM('${L_LAND_TABLE_NAME}' )
ORDER BY A.ORDINAL_POSITION
I dont know the metadata table for SQL Server. But, this concept can be extended for filtering out the columns too as ,
A.COLUMN_NAME NOT LIKE ('V%') AND A.COLUMN_NAME NOT LIKE ('C%')
