Not in (select field from)
Hi All,
Just started on Matillion and so far great to work with. I encounter one issue now for which I can't seem to find the answer.
table with four columns:
field1 - field2 - email - source
I have a Transformation job in which I want to do this:
Select * from table
where
source = 'A'
and email not in
(select email from table
where
source = 'B')
It's the "email not in" part that bothers me. If I use an except component, only the email field would be returned, and I need all columns.
What is the correct way to approach this ? Of course I can use an SQL component, but if possible, I would like to prevent that.
Thanks for your time !
Cheers,
Gerard Verbruggen
Hello @g.verbruggen​
Welcome to the Matillion Community 👋
A method would be to use a Join component and configure it as a Left Join, where you join on the email field. In the Join Output, include the email field from both tables. Right after the Join, add a Filter component and configure that to filter out rows where the email field from the lookup table is Null or Blank.
That should resolve this for you, do let me know how you get on.
Hi Joe,
Thanks a lot ! Sounds logical :o)
I will give it a try somewhere this week and get back to you with the results.
Much appreciated !
Cheers,
Gerard
Hi @g.verbruggen​ I don't have answer for you question, I would suggest whatever you make the transformation maximum go with code base the reason is in case future if you have a requirement to migrate the code raw code would be easy.
