Is there a way to know what user ran an orchestration job?
I'm working with multiple co-workers in Matillion on the same project so we were wondering if theres a way to identify the user that ran a job from the task history or the API.
There's an originator ID but it not that helpful to identify the user.
Thank,
Rick.
How are you handling your users? Are you using exclusive versions to manage each developer/user? If yes, then you can definitely know who ran what and when in the Task history. If you are using a default version , then it gets difficult to trace.
Cheers,
Anu
I have the same question about originator_id, but for programmatically initiated tasks. I have a job that's running multiple times a day, but I cannot figure out what is initiating it.
