My environment defaults to using the Instance Credentials, but I'm trying to use the Text Output component to write to an S3 bucket in a different AWS account that I need to use different credentials for. The S3 Unload component has an option to specify which credentials to use, but the Text Output component doesn't have a similar option. Is there any way to use credentials that aren't the Environment default with the Text Output component?
Hi @ZachB
I know I just replied to another post of yours, the same sentiment with this one, if you need any support with this still, please let me know.
