Data transfer-component sometimes fails due to bad AWS credentials when target is a S3 bucket
I am using the Data transfer-component to load a file from Azure blob storage to an S3 Bucket. I have added the AWS credentials in the credentials manager.
Sometimes I get an error in the Data transfer component.
"Parameter Validation Failure:
Target URL - That URL does not point to an accessible S3 bucket."
This error coincides with the following error when I enter the Target URL field in the component:
The authorization header is malformed; the authorization component "Credential=S0xxxxxxxxxxxxxxxx1lMQ0c=/20210610/us-east-1/s3/aws4_request" is malformed.
(Service: Amazon S3; Status Code: 400; Error Code: AuthorizationHeaderMalformed; Request ID: P3MKxxxxxxxxxNZMP1; S3 Extended Request ID: 2V0P7xxxxxxxxxxxxxxly3bS+s/TRDKxxxxxxxxxUg+dmLttNo1xxxxxxxxxxxZki1nLI6JY=; Proxy: null)
I am having a hard time reproducing the error. Anyone have a clue what is wrong her.
I'm on an Azure hosted Matillion instance, with snowflake as the database.
I have got the same error on S3 Load component whenever the Matillion instance is rebooted .
The credential in the error message of the Target URL field starts with 'S0' while my AWS Key ID starts with 'AKI'.
I am on an AWS hosted Matillion instance.
when i get the error, i have to go to 'Manage Credentials' and click 'Test' button. Then come back to the S3 bucket, and the error is gone .
Any suggestion?
It sounds like we have the exact same problem. I have confirmed that a reboot of the machine makes the problem appear. I currently have no suggestion on how to proceed. Is it possible to trigger a test of the credentials in the job with some scripting maybe?
Recently we migrated to the latest version.We are also receiving same error.
Please give us some advice!
@JoeCommunityManager
What version did you migrate to? According to Matillion support, this should be fixed in 1.54.
i see the issue in versions 1.51 and 1.53.10. when will be 1.54 available?
update on 06/29/2021: I have upgraded to 1.54.9 and I still see the issue
Hi all,
There was a bug related to this that was fixed in version 1.56 if you upgrade to this version, this should be fixed.
I was told the following by a Matillion support person on July 5th
"July 5, 2021 at 11:34 AM
Apologies for this, this issue was fixed in version 1.54.0 but the issue regressed in version 1.54.9, we have raised this internally with engineering and its been worked on. I will update you as soon an update is available"
Have not heard back.
