Is there a way to use python3 interpreter to access databases?
The Jython interpreter requires some access settings to be configured, as we get unnamed module error. I wanted to move away from Jython interpreter to python. The documentation says we cannot. Is this allowed now?
hi @Varada
Could you please share sample code? to check if that can be moved?
@ASD​ Any script that uses cursor = context.cursor(), requires Jython interpreter. e.g
myCursor = context.cursor()
myQuery = "select * from example"
myResultSet = myCursor.execute(myQuery)
THe Jython interpreter fails while making REST API query if we use version of JVM more than 1.8. e.g
requests.get(url,headers). We get the following error:
requests.exceptions.ConnectionError: ('Connection aborted.', error(-1, u'Unmapped exception: java.lang.IllegalAccessException: class org.python.core.PyReflectedFunction cannot access class sun.security.x509.X509CertImpl (in module java.base) because module java.base does not export sun.security.x509 to unnamed module @36aa52d2')) in <script> at line number 101"
We have to set the following environment variable for JVM.
--add-exports java.base/sun.security.x509=ALL-UNNAMED
