I added the webhook component to the canvas and configured it by setting the Incoming webhook URL, selecting the Payload Template I created, and then mapped the payload variable to the job variable. The error comes when I map the payload variable to the job variable.
I cannot get this Payload variables to map without validation errors. Unlike other components, the webhook post component will not run at all when there are validation errors.
Anyone else experience this? If so, were you able to get around the issue? If you were able to resolve the issue, how did you do it? Thanks for the help in advance!
Product: Matillion for Snowflake (Enterprise)
Version: 1.53.8
Cloud Provider: AWS
Instance: Single (non-clustered) Instance as m5.Large
At least the screenshots looks quite the same as your issue :) Didn't go further with this one at that point. But would be interesting to actually have these pretty formatted Teams-messages popping from Matillion.
It might be a bug, due the value field doesn't really accept any values.
Thanks for the response @MichaelBoucht (Customer). I have had a support case open for a few weeks now. The only response I have received indicates that Matillion can't replicate the issue on their end. I am glad I am not the only one that has had this issue. Thanks again and I will post the results of that case here once it's resolved.
Hi @MichaelBoucht and all others that read this thread. I did in fact find a bug in the Webhook Post component. This affects all versions up to and including 1.54 and likely a few more versions after until this bug is fixed.
The situation is this, when you use a Payload Variable and the variable has a capital anywhere in the variable name, it will appear to work until you go to map the Payload Variable to a Target Value but will fail at that point. Long story short, you can't use a capital any where in the name. Here is an example:
@ian.funnell That's giphy is a variable in a Payload Template, was planning on having a massive list of urls stored in Snowflake table that are randomized dependent on the outcome... And maybe have a this whole component as a 'shared job'
Hmm, I think I am using too much time for this ;-)
