Loss of precision/space postgresQL to Snowflake with JDBC Incremental Load component
I’m trying to use the JDBC Incremental Load component to load data from postgresQL to Snowflake. When I load numeric fields with decimal values, they come across as number(38,0) and it truncates the value. How do I make sure the values come across with their decimal values?
Hi Julie,
That's maybe one for tech support in case it's a known issue. Meanwhile, perhaps there's a workaround if you manually adjust the datatype of the Snowflake column in the target table?
Best regards,
Ian
