Updaten grid variable (null)
Hello
we try to ingest data from SQL SERVER into Snowflake
therefor we are using the JDBC incremental compoenent.
We though we can script the TABLES; COLUMNS;IS_INCREMENT,IS_KEY
  1. so first step is defining all the tables we want to ingest => define in a grid variabel (ok)
  2. reading all column meta data for all tables from source database (sql server) (ok)
  3. having a pyhton script which generates a grid variable with the table, column, is_increment, is_key which would be used in the "jdbc incremental component" (update the grid variable is causing some trouble)
here is the script
``py_my_grid_variable = context.getGridVariable('gv_tables_cols')
print(py_my_grid_variable)
# Only do the rest if the grid variable is not empty, and contains more than 0 values.
# Otherwise the default, empty value of py_my_scalar_variable will persist
gv = []
py_my_scalar_variable = ''
if py_my_grid_variable is not None:
 if len(py_my_grid_variable) > 0 :
  ## Matillion grid variables are lists of lists.
  for x in py_my_grid_variable :
   g = []
   if x[0] == jv_column_isincrement :
    is_increment=1
    is_key=0
   else :
    is_increment=0
    is_key=0
   g.append(jv_table)
   col = str(x[0])
   g.append(col)
   g.append(is_increment)
   g.append(is_key)
   gv.append(g)
  a= context.updateGridVariable('gv_metadata', gv)
  print(len(gv))
  print (context.getGridVariable('gv_metadata'))
the problem is that
it is updating the gridvariable a kind of but is failing for some reason
when we print out the grid variable gv_metadata than there is some null after the array
which is strange , because when we print the array of list gv than it looks fine
Does anyone have some ideas why the context.getGridVariable('gv_metadata')) is not properly working?
Thx Martin
whole output looks like
[['property_id'], ['DS_Load_ID']]
2
[['properties', 'property_id', 0, 0], ['properties', 'DS_Load_ID', 1, 0]]null
if I print the update grid variable at the end it seems that it has
put for some reason the updategridvariable makes some null at the end
and the component is then failing without any further message
so the pyhton component is failing without any further information
and if I than say in case of an failure use a next python script to print the grid variable
the variable is update
put I dont know why the python script reports a failed task
here you see the workflow
and you see that the first python script is failing
