Matillion Pipeline Statistics
Hello Matillion Community,
Just trying this out, to see if there is anyone out there that has done this before.
SITUATION: I would like to track historic status of pipelines that are scheduled. For example over the last year how many times in the last year has production_pipeline_a failed.
BACKGROUND: Currently I plan to do this querying the Matillion API, gathering the data and then pushing it to Snowflake
ASSESSMENT: Interested to know if there is an easier way anyone has extract the success/failure rate of Matillion jobs
RECOMMENDATION: Reply, let me know what you have tried and whether its been helpful to see these statistics. I will try and update you on my progress.
Aim: Hopefully spur on some conversations around the data we can extract from Matillion ETL and how helpful you have found it.
Its’ solved here: Task History - Matillion Docs
I guess we can switch the topic to see how people have used the data?
