Need Facebook side of OAuth setup steps for Matillion Oauth to connect successfully
Dear all, Looks like Permissions setup at Facebook side has changed from what is in the matillion documents & now, it needs 'App Permissions' & 'App Domains' to be defined in facebook it seems.
Has anyone had success in connecting to Facebook ?
Hello @Murali
Thank you for your post, you are correct there have been some changes by Facebook, our documentation team are already on the case and are working on updating our documentation in relation to this.
As soon as that is done, I will be sure to share it here for you.
It's brilliant you shared this here as many other users will likely be in the same position too 👍
Thanks Joe. Pleasure is mine. Looking forward for the modified documentation.
Muralidharan Balakrishnan [ Murli ]
Director – EDF Development
Fair Square Financial
Phone: (952) 288-8899
[cid:image001.png@01D6FFB5.2960EDF0]
“It is not our abilities that show who we truly are; It is our choices. - Prof. Dumbledore”
Hello @Murali
Our documentation has been updated to reflect the changes by Facebook, thank you again for pointing this out to us!
https://documentation.matillion.com/docs/2339839
Thanks Joe. now the steps look very clean.
from my end, the App Domain seems to be blocking factor as we are not having a domain name assigned for the EC2 instance. Once i overcome that, i believe, the rest of the connectivity will work fine.
