I have a Main Job with One Orchestration and five transformation, which run parallely, while running I want all job to start parallely but every time one or two transformation jobs / orchestration job is not starting initially its keep on validation condition untill any one of the three transformation job to complete then it getting the running status. So, only four jobs can be ran parllely or else any other idea for solve this.
Hi @Joe-Community-Manager
Thanks for looking,
Looking forward for the solution.
Regards,
Hari
Thanks @HariRamK
We are still looking at this, I will pop a response once I have an update for you.
Hello @HariRamK
I am afraid what you are trying to achieve is not possible within Matillion ETL, this is explained here.
You can do this using the Matillion Data Productivity Cloud, I would be happy to reach out internally and ask the team to contact you for a demo of this?
Let me know what you think.
Hi joe,
Thanks for info , I will dicuss with my team and reach you back any help needed.
Regards,
Hari
