OData Connector for SAP ERP
Hello all,
We are looking to use the OData connector in Matillion to source data from SAP ERP data sources, specifically the Operational Data Provisioning (ODP) models.
I am able to connect and extract full data loads successfully, but when trying to use delta mode I can't get the parameters right.
Based on this blog post:
https://snapanalytics.co.uk/get-your-sap-data-into-snowflake-with-matillion-using-odata/
have setup, but when using the Connection Options to set the CustomURLParams to include !deltatoken='....' it either fails with error 400 (if include leading "!") or doesn't recognise the token and just initialises again if I include it.
It also seems problematic when trying to include multiple CustomURLParams, in this case we need to provide both sap-client & deltatoken. Using the document for OData to define how to specify parameters.
https://matillion-docs.s3.eu-west-1.amazonaws.com/datamodels/OData.html#RSBOData_p_FeedURL.htm
Wondering if anyone has been able to successfully get this working. We are using Matillion 1.51 - had some issues upgrading in the past.
Michael
