Offset-based pagination SendinBlue API Query not working
I am currently trying to create a connection to Sendinblue with the API Query component and add a offset-based pagination. The connection works and the query component will receive the first page, however it will stop after 1 iteration.
included is the .rsd file.
@b.verburg​ did you got any work around
I'm using Coupa API which also uses offset/limit - getting same result,  API Query component stops after 1 iteration when run in orchestration.
Opened support case to see if we can resolve.
