I am Using Oracle Output Component For writing Snowflake data into Oracle, The Oracle Output Component is failing But its not giving any error message.
Can any one help me out?
It can be due to null records in the source table. Oracle output component fails to load null from source to target.
Hi , I am also facing same issue. Oracle output component fails to load null from source to target. I have checked yes it is nulls in my source. What should I do to fix this issue?
