Source: QuickBooks Online
Destination: Snowflake
The pipeline runs once a week right now (it's in test/demo stage) and every time it says the pipeline failed, but new records have been moved and the full log doesn't show any discernible error message. Incredibly vague, opaque, and user-unfriendly. How can I pinpoint the error? Is there even an error?
Hi @jonathan17 and welcome to the forums!
Would you be able to share any logs so that we can take a further look, please? Could you also share your exact pipeline name too? Feel free to DM them to me if you'd prefer.
HI Claire! Just circling back, I DM'd you the logs on the 18th.
Hi @jonathan17 I'm sorry for the late response and thanks so much for your patience!
The team has had a look at the logs you shared. Could I ask you to double check your connection information to your Quickbooks instance? Are your credentials still valid for example. Would you also be able to check if your table and column names are correct/consistent too?
Thanks so much and please let me know if that helps at all.
