Is there any way to restrict environments for each versions, means My version should not have access to QA environment it should show only DEV environment
Hi @yakkalabadari and thanks so much for your question. I've checked in with the team about this and they said that there's no way to prevent an environment being seen by a particular version, but have suggested to try using different projects as you should have more control via that route. Let me know if that helps!
Many thanks, Claire
