Hi Everyone,
I am using Matillion ETL for Redshift running with 1.42.7 version in my production environment. I have started facing issue since last week of utter slowness specifically in transformation jobs. At a given point of time, only 1 transformation job runs even though that is totally different than other jobs, which makes the job runs 4-5 times slower than earlier.
Any help would be appreciated to resolve this issue.
There are various factors to consider for slowness in the jobs. Below are few you may need to check:
1.Matillion VM size (No of vCPUs)
2. Redshift cluster size ( not sure if that is what defines the performance, for Snowflake its the warehouse sizes )
3. Matillion concurrency (No of possible connections to the database )
Hi Anudeep,
Thanks for your reply on this.
To answer on the points you have mentioned, issues started appearing suddenly from 26th-May onwards and before that things were working perfectly fine in Matillion.
Mithil Prajapati.
