Staging bucket is not visible
I am trying to connect to Amazon Redshift as a destination. I have the credentials added and tested. When I reach configuration tab in Tasks, staging bucket field does not show any values. It throws error. There should be a bucket visible since the user has access to it via bucket policy.
The bucket is kept as private, but the user is given access using bucket policy.
Hi @MA414857​,
Have you granted your Matillion instance the s3:ListAllMyBuckets privilege? Matillion ETL uses that to generate the values for the dropdown list. Please see this document for a list and description of the fine grained IAM privileges that Matillion ETL can use.
Best regards,
Ian
