did I messed up somewhere? I can’t seem to run a simple dbt --version to test out mat and dbt integration
Hi @_Jack
Thank you for your post, and welcome to the Matillion Community. It is difficult from the information shared to distinguish what may have caused this, but our support team will be able to take a more in-depth look into it for you.
If you can raise a support case, they will be in contact and able to take a look at it for you.
@Joe-Community-Manager I think you want @_jack ![]()
Thanks @Jack
I appreciate the heads up ![]()
