We're currently running Matillion version 1.70, which comes with dbt core v1.3.1. That's a pretty old version of dbt though and it's incompatible with some of the dbt packages we're using. Is there a recommended path for upgrading to the latest version of dbt core? I tried just using pip to upgrade the dbt-core, dbt-postgres, dbt-redshift, dbt-snowflake, and dbt-bigquery packages, but that seemed to break things.
Hello @ZachB
Thanks for your post, as this is related to upgrading, we would recommend you speak with our support team, you can raise a case here.
They will be able to take you through the best approach and support you throughout.
I hope that helps, if you need anything else, please do let me know.
Have a great day, Joe.
