I’m using Matillion ETL for Snowflake, and want to load data into Snowflake from an Azure SQL database. I found the docs for the Azure SQL Query connector, which seems to be exactly what I need, but I can’t find the connector in my Matillion instance (Version: 1.75.4 (build 3739c66-338846)).
I searched the release notes to see if it was added in a later version and don’t see it mentioned in versions after 1.75.
When I search for Azure in the Components panel this is all I get:
Do I need to do something to enable the component? Thanks!
