I have a custom connector that is not populating the matillion fields? (identifier, partition, batch_id, timestamp) for one of the endpoints. They are populated for one endpoint but not the other. The endpoints are set up the same.
Hi there @egeorge and I'm sorry for the late response to this.
If you're still having the above issue, could you please let me know the following items?
- Have you set a unique tablename for each endpoint (under general)?
- Have you set key(s) which define uniqueness of a record (under keys)?
- When selecting the data (under behaviour), are there any arrays which could be empty? If so, deselect these for now.
- Are all parameters correctly set - query, header, URI, or Body (under parameters)?
If you can let me know the answers to these, we should be able to help you further. Thanks again for your patience.
Thanks. @ClaireSeniorCommunityManager
All of those items were covered. The matillion fields started getting populated without any change. Not sure why the problem started nor how it got resolved, but it appears to no longer be an issue.
@ClaireSeniorCommunityManager Thanks. The API is Smartsheet. https://smartsheet.redoc.ly/
Thanks for letting me know @egeorge and I'm glad to see the issue has gone! Please let me know if it reappears at all.
Thanks again!
Hi again @egeorge, I caught up with the team about this and if you'd be willing to share, they're interested to know what API you were using and any other details you'd be willing to share. You can send this to me via a DM if you'd prefer.
