All of my data loaded to Snowflake is NULL?
I am loading data to Snowflake using a MongoDB Query component. I am populating a grid variable with columns to pull from my Mongo source. My job runs and completes successfully, retrieving the right number of rows from the source however every value in each of the tables is "NULL". I have tried running the Mongo component with the 'recreate table' property set to yes and no; nothing was effected by changing this either way. I'm kind of at a loss at what would cause this behavior. Thanks!
Hi @JasonM​
It seems you have managed to leave the community speechless, a rarity!
Our support team will be more than happy to look into this for you, if you can send them an email they will be able to investigate this for you..
Please do keep us posted on the resolution for this, I am sure the rest of the community would love to learn it too!
Thanks Joe
