I'm using the Matillion Hubspot Component to load properties from Deals. However, I am finding, some properties exist while others dont, Are there certain properties certain fields in Hubspot need to satisfy to be passed to the Hubspot API?
Hi @Rashmi
Sorry for the late reply to your post, I have just come across this now, can you confirm if this is still ongoing and if so what properties are missing, please?
Thanks, Joe
Hi Joe!
The issue eventually resolved itself. The properties in question were custom user created ones in the Hubspot in the 'Deals' Object. They did eventually auto-magically appear 4-5 days later and i could pull them through the Hubspot API Component into Matillion for additional processing.
I hadn't had this issue since or before this once instance. Usually properties are discoverable in the Matillion Component immediately.
