Data Transfer component causing failure after upgrade to v1.63
We use Data Transfer component to copy files from On-premise Sharepoint to AWS S3.
It was all working okay till we had upgraded to v1.63.
After the upgrade the component is failing with the error message.
java.sql.SQLException: HTTP protocol error. 401 Unauthorized.
Have you guys ever had this issue.
Cheers,
Anu
Figured out the issue. It was surprising to see that the previous version of Matillion allowed usage of "Sharepoint On-premise" as Sharepoint Edition option, though we are connecting to Sharepoint Online.
This seems to be fixed in the new version. Changing it "Sharepoint Online" worked for us.
Cheers,
Anu
