Fully automate Matillion ELT by using Powershell with Microsoft Task Scheduler
Hi Matillion,
I am working a project to fully automate the ELT flow. Although I know that Matillion itself has a feature of Task Schedule. But for porduction, scheduling the job would be relied on IT support to help run them sequentially. Is it possible to make use of Powershell script with Microsoft Task Scheduler to connect with Matillion API to run the ELT project flow in Matillion ? Thanks.
Hi @dennis.lee​
I have just seen your post, If you have not already, I would recommend raising an idea on the ideas portal here.
This will be reviewed by our product team and potentially implemented into the product!
