Every Keytouch Matillion starts to validate the whole job. When the job is big it's a never ending validation story and it's most terrible. How can I stop validation??????
@maike.osterbrink In the task bar you can simply right click on your validation job and click Cancel Task. It will terminate your validation process.
@maike.osterbrink @jeberson_david I also think that the good idea for this, I am also using the same.
Thanks a lot for answering. I tryed it, but when i click to cancle the task, it never care about and go on with validation.
we are using Matillion ETL
Version: 1.74.0 (build 8216629-266405)
Image Version: 1.74.0
@maike.osterbrink Have you tried ctrl+right click on the validation job and then we need to give Cancel task and continue
@jeberson_david Wow, yes. That's work. A lot of Thanks :) You made my day!
@maike.osterbrink good to hear Finally You got the answer
