Please can you help query to extract list of all Project and sub project folder names ?
any reply ?
Hi all,
I am going to look into this for you, I will pop a reply here once I have the information.
Hi all,
To check are you referring to the rest API? if so you can use the version debug endpoint and then parse the JobsTree object :)
I hope that helps, please keep me posted.
