Is it possible to get the "folders" in job path?
I'm trying to get a list of our jobs (transformations and orchestrations) for use in a tool that I'm going to be working on and I was looking at the MetaData API - but the URLs which show in there just have project/environment/job_name while in the UI we have them arranged in folders (sometimes a few levels deep).
Looking at the UI, I can see that the URLs there don't actually show the folders either but they do exist so something, somewhere, must know about them!
Can anyone give me any pointers as to how I might go about getting a list of jobs organised into their folders?
Hi @LMenz​,
In looking at the documentation and experimenting a bit with the API, the only way to get this is to export the project. Since a given project can have 1 to n versions I would focus on one that you know will always be there. For example we have a version called CURRENT in all of our projects which is the version we use in all schedules and is considered the "released" version. In this scenario I would export the specific version of the project. The response is going to be quite large but it sounds like you will only need to focus on a couple of attributes. Those attributes being things like Job Name, Job Type, and Job Path. For those items below is their respective paths in the JSON:
/objects/jobs/objects/info/name
/objects/jobs/objects/info/type
/objects/jobs/objects/path
Path is what you are likely going to be interested in. Path is an array of names. For example, if a job were in the following path, "Archive/Old/Jobs" the Paths array in the JSON will be Archive, Old, Jobs.
I hope this helps! Post back if you need more help.
