My project contains many folders that are separate ETLs. When working on one ETL within one folder, sometimes I'd like to find components within that folder. I don't want to do a global project search.
Hi @andrew.terwielā and welcome to the community!
I've had a check with the team and while the UI does not allow for folder-specific searching. you can export/import the subset of jobs into a new project and search there. I've been given the following steps for you to try;
- Export the contents of the folder
- Create a new project
- Import the exported jobs
- Now search (bottom right) for the relevant keywords
Let us know if that helps!
