Save sql results in a variable and use it another sql
I have a table from where I will be pulling dates and using those dates in where clause of another sql.
eg
query1
Test_var= select date from date_table
Query 2
select * from table where date=test_var
and append the data in a table
Loop until the end of results of query 1
Hi @kanika3010​
Store complete data from Query one in one table and use table iterator attached to transformation with Query two. Pass variable used in iterator through transformation scalar variable.
You can use a Query Result to Grid component to capture the results from the first query and use a Grid Iterator to iterate through the values passing to the transformation job. This way you can avoid creating another intermediate table.
Can u create a small template job and post. I am really a basic user and dont know much about it
Hi @kanika3010​
I will try to attach job template but meanwhile steps here:
You will have to create one job variable in both transformation and orchestration.
  1. 1st Transformation - which will run your Query 1 in SQL component and write it to a table using rewrite component.
  2. 2nd Transformation - Second query in SQL component with {variable_name} wherever required and write it to a table using rewrite component.
  3. Orchestration -
  • Add 1st transformation
    • Add table iterator component pointing to table created above
    • The same variable will be used in table iterator
    • Attach table iterator with 2nd Transformation
    • Add variable value to pass in 2nd transformation as scalar
I hope this helps.
