How to Temporarily Pause Slack Webhook Notifications in Matillion
Hi Team,
I created a platform-level notification using webhook and Slack in DPC(MAIA FOUNDATIONS). If I want to temporarily pause the notifications, I currently see only Edit and Delete options, but no Pause option. Is there a way to pause the notification within Matillion itself or no such option available?
I understand it may be possible to disable the webhook from the Slack side, but I am specifically referring to pausing it from within Matillion.
Thanks!
Hello @Hemanth
Thanks for your post and question, what you have asked for is not currently available but I think it would be a really good idea to raise on the [Roadmap and Ideas site](https://roadmap.matillion.com/) The team will review and look to implement this in the future!
