How to use IN operator in matillion
I have two data sources D1 and D2 and i want to filter data from D1 using condition :- SELECT * FROM D1 where D1.customer_key in (select customer_key from D2)
Hi @shivamsachan303​
The query syntax that you wrote seems to be working.
You just have to use a SQL query component that is taking data from both tables (D1-D2) and you should be able to do it in Matillion.
@shivamsachan303​ instead of relying on a subquery, you can achieve the same thing using an inner join. You can use the Join component to achieve the same.
Hope this helps.
Thanks for the reply, Is there any way to do it without using SQL component as to use SQL component there should be a source table but in my case I do not have source table here data is coming from matillion join component
You can use any component in matillion as a source table in case its connecting with your SQL query component.
You have to use $T{JOIN COMPONENT NAME} as your table name in query.
Thanks, it worked for me.
Glad it helped 😀
I have one more query is there any way to perform group by operation using calculator component.
You can perform it using aggregate component or SQL Query.
