Is there a way to pass grid variables to a transformation job and have the "Read"/"Write" components access the variables?
I'm working on CDC for my warehouse, and with the warehouse size increasing, I want to add a scalable methodology for my CDC. The CDC is done in 3 steps, 1. Insert New Records 2. Insert Changed Records 3. Close out Changed (Old) Records.
Hoping to complete the 3 steps through variables for table names so I don't end up with a hundred components doing the same thing.
I know one way to go about it is Shared Jobs, but just looking for some direction.
You can pass Grid variable values to transformation using Grid Iterator. You need to configure the grid values for each iteration to pass in transformation using environment variable.
Check this --> https://documentation.matillion.com/docs/2943274
