JDBC Incremental Load wizard loses connection when trying to load up many table objects on Step 3 (Data Sources)
So I've encountered an issue on Step 3 of the wizard (Data Sources). Our database has MANY tables (over 50k...don't ask). The wizard takes some time to populate the screen and when it does come back from the loading icon, the screen immediately says 'Connection lost, attempting to reconnect'. Obviously since it refreshes the screen, the wizard is closed and I'm forced to try again. The same thing happens every time. I'm not sure if this is a limitation of Matillion or the memory in my machine.
Hello Derek
I would suggest opening a support ticket for this issue, as I have the feeling our team would have to investigate how to get the JDBC Incremental Load wizard to handle a massive list of tables without fault.
Regards
Matillion Product Team
