looking for info in matillion properties settings to change the snowflake role connecting to Snowflake .
The role being used is defined in the Environment of the project. It's often missed because usually Environments are setup once and then forgotten. Check out your environments. The documentation around environments can be found here: https://documentation.matillion.com/docs/2679765
I hope this helps!
Hi @Bryan — it's good to see you!
Guide is helpful.
