Matillion connection to PRMS; User-defined requires X11 Display parameter. How can I bypass it?
I am using Matillion in order to connect to the PRMS ERP system.
I am using the database query component with the following parameters:
Database type: IBM DB2 for i
Connection URL: jdbc:AS400://12.123.1.123/ALIASLIB
However I get this error: No X11 DISPLAY variable was set, but this program performed an operation which requires it.
I think that the problem is that the user credentials that I am using are meant to be utilized on a graphical interface. Is there a chance, however, to bypass this? Thank you!
