I am a member of the Matillion product team, and I am looking for use cases for a proposed DynamoDB Output connector. I am looking for details on:
- What platforms this would be useful for (Snowflake/DeltaLake/RedShift/Synapse)?
- What is your business use case for this functionality?
- What features / capabilities would be vital for this connector to be considered successful?
Thank you for any feedback you may be able to give.
Hello, we have one use case.
1) Snowflake/AWS
2) We have API's that use DynamoDB as their main operational database. We have a daily/monthly synchronization of some metadata stored in Snowflake towards DynamoDB. This is at the moment done as csv -> s3, and lambda s3 -> dynamoDB. This works fine, but would be awesome to be able to directly throw data into DynamoDB as per defined.
3) I would guess a basic functionality to have a table -> column mapping, as 'columnar' as possible.
And with more advanced, maybe generate some JSON with some various depth dependent on requirements.
I can give you more examples if required :)
Hello Michael
Thank you very much for your response.
Can I ask that you further elaborate on, "generate some JSON with some various depth dependent on requirements"?
Regards
Ben
Matillion Product Team
Hiya,
I guess creating a nested json by the fly was the one I was after there :)
Example,
Let's say a table,
ID|Product_ID|Product_Name|Effective_Start|Effective_End|Effective_Price
1234|321321|Product Name Example #1|2020-01-01T00:00:00.000Z|2020-02-01T00:00:00.000Z|100.00
1234|321321|Product Name Example #1|2020-02-02T00:00:00.000Z|2999-01-01T00:00:00.000Z|99.00
The json structure I would want from this is,
"ProductList": [
"ID": {
"N": "1234"
"Product_ID": {
"N": "321321"
"Product_Name": {
"S": "Product Name Example #1"
"Effective": [
"Effective_Start": {
"S": "2020-01-01T00:00:00.000Z"
"Effective_End": {
"S": "2020-02-01T00:00:00.000Z"
"Effective_Price": {
"N": "100.00"
"S": "2020-02-02T00:00:00.000Z"
"Effective_End": {
"S": "2999-01-01T00:00:00.000Z"
"N": "99.00"
