Hi I have two questions ,
1. Is there any way to connect ZOHO desk through matillion? I tried it using Zoho CRM Query component but I couldn't make it.
2. How can I connect Zoho API through matillion?
Hello @jeberson_david
You can connect to Zoro CRM, but not Zoro Desk, I would recommend raising an idea and the product team can look at that for you :)
Hello. we have connected to Zoho Desk using the API Query component. However, we are trying to figure out pagination.
Hi ! Thanks for the reply, yes we already connected Zoho Desk using the API query component and we are using it.
How do you handle the pagination? Would you be able to share your source code?
