Quering Date Stripe connection
Hi all,
I guess I have a pretty basic question. We are currently using the stripe connector. With some tables I get the error message: "At least CUSTOMER should be specified in this SQL statement.
In the documentation (https://matillion-docs.s3.eu-west-1.amazonaws.com/datamodels/Stripe.html#pg_table-cards.htm) it says:
"In addition to CustomerId, provider supports all columns to be used as criteria in the Where clause of Select statement, as long as SupportEnhancedSQL is set to True. If SupportEnhancedSQL property is set to False, you still can retreive a Card by specifying its Id"
"as long as SupportEnhancedSQL is set to True." Enyone knows where I can set it to true?
Thank you very much for your help.
Kind Regards
Michael
