URLDecoder: Incomplete trailing escape (%) pattern
How do I pass an api parameter that requires the percent sign?
I need to send a parameter like this: Message=Archived%
This works when I setup the endpoint in API Query and also works when I run a Sample. However I get the error message in the subject when I try to run the component.
I'm connecting via API Query to simPRO api.
https://developer.simprogroup.com/apidoc/?page=ff7c0fcd6a31e735a61c001f75426961#tag/Search-resources
Cheers
I have attached the log below
This is a definite bug in the Matillion API Query usage of Javas URLDecoder function.
@MatillionProductTeam​ Hope you can take a look and address this. Cheers!
Hi @SB699925
To best solve this, I suggest to raise a support ticket and share the RSD, if possible. This potentially calls for engagement with the Engineering team.
Thank you,
Chika
