We called Matillion Lineage API, but sometimes it returned below error.
Do you have any similar things or any suggestions?
Thank you.
hi Sunny, am also facing the same issue.
Could you pls share if there was any resolution for that error?
Regards,
Kumar.
@Kumar I did ask Matillion Support team about this earlier. They had a bit stuck at that time to figure the root cause out for this issue. However, they recommended us with a solution and it worked well. The solution was that we could use the Batch Size Connection Option and Timeout Connection Option set to 0
