Fix this Issue
Found new bug when I move note component I’m getting some pop ups like “failed to move the components. No such Component found” but that note is present. So please have a look on this.
Hey @HariRamK
Thanks for raising this with us, I will pass this onto the team now. I will pop back with an update ASAP.
Thanks Joe
Hi @HariRamK
Can you kindly confirm which version of Matillion ETL you are currently using please?
Thanks Joe
Hi @Joe-Community-Manager,
Thank for quick response we are currently using Version 1.77.7
Thank you @HariRamK
This has been fixed in Version 1.77.8 it will be fixed when you upgrade.
Ok I will, Thank you @Joe-Community-Manager
