Matillion keeps spawning components that I remove
I face this issue every day with some filter component that I used for UAT that now is in an invalid state and it keeps popping in the job when the process starts on schedule. This causes the process to crash, so I need to remove the filter and rerun.
How can I investigate this further? Thank you!
Hi @Bobec
I am sorry to hear you are having that issue, It seems quite peculiar and will for sure need support to take a look with you, I have raised a case on your behalf. The support team will be in contact soon.
What was the solution here? I have the same problem.
